THEMA: Wagen mit funk kamera
vlakci - 29.09.14 10:31
Ich bin fertik bis jetzt mit 4x kamera wagen + 1x lok. Als Deutsch ist nicht mein erste sprache und umbau beshcreibung ist sehr lange ich screibe in English:
receiver
- DVR-730 = 2.4GHz, 100m, 8ch (4 NTSC, 4 PAL)
http://s2.mojalbum.com/3331232_17504691_18535075/kamera-vlaki/18535075.jpg
firts waggon job Roco
- camera MC900 = PAL 640x480 color, 9.5x9.5x12mm, 3.3-6V/70mA
- wireless transmitter MM102 = audio+video, 9.5x25mm, 2.4GHz, 100m, 3.3-6V/50mA
- self made el.circuit with AC/DC->DC, 6-18VDC->DC/DC converter->6V, backup capacitor charging with constant current at 100mA
- 2F/6V goldcap for 40s of work without power
- additional white 350mCd LED for illumination in night
- 4x AUX function decoder FH05A D&H (camera ON/OFF, akku ON/OFF, LED ON/OFF)
http://s2.mojalbum.com/3331232_17504691_19263442/kamera-vlaki/19263442_z.jpg
http://s2.mojalbum.com/3331232_17504691_19263443/kamera-vlaki/19263443_z.jpg
http://s2.mojalbum.com/3331232_17504691_18535078/kamera-vlaki/18535078_z.jpg
first test
http://s2.mojalbum.com/3331232_17504691_19263441/kamera-vlaki/19263441.jpg
second job MTX doppelstock
- camera CCGE-2058 = PAL 720x480 color, fi7x26mm, 3.3-5V/110mA
- self made el.circuit with AC/DC->DC, 6-18VDC->DC/DC converter->5V, backup capacitor charging with constant current at 100mA
- 2F/5V goldcap for 40s of work without power
- 2x AUX function decoder FH05A D&H (camera ON/OFF, akku ON/OFF)
http://s2.mojalbum.com/3331232_17504691_19263425/kamera-vlaki/19263425.jpg
http://s2.mojalbum.com/3331232_17504691_19263429/kamera-vlaki/19263429.jpg
http://s2.mojalbum.com/3331232_17504691_19263438/kamera-vlaki/19263438.jpg
first test (right picture on screen, from MTX on track, Roco on the left)
http://s2.mojalbum.com/3331232_17504691_19263440/kamera-vlaki/19263440.jpg
third job - FLM OBB2016
- camera CCGE-2048 = PAL 720x480 color, fi4.x12, 3.3-5V/70mA
- 0.11F/5V goldcap for 1-2s of work without power
- Motor decoder with 4x AUX D&H (camera ON/OFF, akku ON/OFF, light FF, light RR)
4th - FLM DB gepäckwagen mit schluss licht
- camera CCGE-2058= NTSC 720x480 color, fi7x26mm, 3.3-5V/110mA
- 0.5F/5V goldcap for 2-3s work without power
- 4x AUX function decoder FH05A D&H (camera ON/OFF, akku ON/OFF, LED yellow, LED red)
picture in future
5th - MTX KPEX gepäckwagen
- 0.11F/5V goldcap for 1-2s work without power
http://s2.mojalbum.com/3331232_17504691_21981964/kamera-vlaki/21981964.jpg
http://s2.mojalbum.com/3331232_17504691_21981966/kamera-vlaki/21981966.jpg
http://s2.mojalbum.com/3331232_17504691_21981968/kamera-vlaki/21981968.jpg
http://s2.mojalbum.com/3331232_17504691_21981970/kamera-vlaki/21981970.jpg
red is camera, green is transmitter, above circuit is AC->DC->DC/DC->MOS switch ON/OFF and current limiting, between is function decoder FH05A, bottom 2x 0.22F/2.5V low ESR goldcap
Quality is good enough, after first use, the focus lens must be set.
First test video
https://www.youtube.com/watch?v=0o2uvmFjxpU&...-SMfeRO19bD0DasEtzdQ
https://www.youtube.com/watch?v=idy6TOjjos8&...DasEtzdQ&index=7
before I added 2x capacitors 220uF to eliminate the glitching (voltage on camera jumping from 5V to 4.5V because of dropp on ESR resistance.
Hallo Nejc,
Tolle Lösung! Kannst Du vielleicht mal einen Schaltplan zeichnen und hier verlinken?
Cool solution! Could you provide a sketch that shows what is connected where? (mainly decoder, goldcaps...)
toll gemacht! Beachtlich wie klein die Kameras schon sind...
lg Michi
Hi !
Also wenn ich mal ehrlich sein soll, die gleiche Bildqualität, leistet eine Feuerzeugkamera für 15 € auch sogar mit Ton.
https://www.youtube.com/watch?v=d3seW0rt4pw&list=UUTNuWBgRklRSZQHlGuuLBAg
Hallo Nejc,
that´s very wonderful. Good job.
Can you tell me the prices of the used parts?
Thanks  a lot in advance,
@Thomas:
Das schon, aber die Feuerzeugkamera überträgt das Bild wohl kaum Live auf den Monitor Micha
www.n-modulbahner.de
@twingo: das ist ein kamera mit funk oder memory-card? Strom auf gleis oder AAA/LiIon akku? Ich weiss fur kamera als Fernbedienung Nachahmung (model #18 auch mit H264 720p gut bild), aber dass ist nicht funk aber nach memory karte.
@akuhtz und minow24:
gleis 14-15V alle protokolen (SX, DCC)->
4 dioden SMD0603 fur AC/DC max 500mA/20V->
pararell ein klein kondensator 1-10nF/20V/SMD0603->
DC/DC SOIC8 MC34063 geplant fur in25V/out5V/out250mA->
- SOT323 MOS N-ch schalter fur kamera ON/OFF kontroliert von AUX0 (normaly open scahlter fur analog spiel),
- pararell  am 5V spannung noch ein SOT323 MOS P-CH fur kodensator ON/OFF (normaly closed schlater) und dann serial ein SOT23 PNP transistor mit SMD 06032V zener diode + SMD 3ohm widerstand fur kondensator laden bei konstante 100mA bis 5V
4 draht auf platine. 2x kamera (decoder schaltbarr am mase NO), 2x kondensator (decoder schaltbar am 5V NC):
- 2x von kamera am funk platine->3 am kamera (mase, 5V, video)
- 2x von kondensator am 2x serial goldcap (benutz 4x low ESR jede 0.22-4F/2.5-5V - beide müssen gleich sein!)
kontrole von platine mit D&H FH05A - benutze ein decoder mit "-" ausgang von min 1V spannug als mit masse von platine (Vgth~1.5V). Nicht moglich mit 5V logik ausgang als mit ESU lokpilot AUX1/2 oder loksound MTC21 AUX3/4. mit alle 4 kamera wagen habe benutze D&H.
Preise:
- platine bauelemente zirka 10€: 2x MOS, 1x PNP, 1x DC/DC, 5x dioden, 1x zener, 4x kondenzator (2x tantal, 2x keramik)
- decoder 20€
- goldcap 1-5€ jede (nur problem als von USA bei Farnell bestellung)
- camera 20-30$
- funk transmitter ~10$
- funk receiver 2.4ghz 4ch PAL + 4ch NTSC ~20$ (mit programe)
Alle zussamen ist zirka 70€ pro wagen.
umfag differenz mit normal 720p H.264 kamera mit micro sd memory card und meine benutzt MC900 (9.5mm). CCGE2058 und 2048 ist noch kleiner (7 und 4.2mm). nur problem als 2048 ist nicht mehr lieferbar :(.
http://s2.mojalbum.com/3331232_17504691_19034194/kamera-vlaki/19034194_z.jpg
meine platine
http://s2.mojalbum.com/3331232_17504691_21989363/kamera-vlaki/21989363_z.jpg
http://s2.mojalbum.com/3331232_17504691_21981963/kamera-vlaki/21981963_z.jpg
http://s2.mojalbum.com/3331232_17504691_21981965/kamera-vlaki/21981965_z.jpg
IC2 = MC34063 DC/DC (modul mit 2x widerstand, 1x spulle und 1x kondensator)
C1 = 2x serie golcap 2.5-3V
T4 und T3 ist fur AUX0 und AUX1
C3 = 220uF/6V Tantal
C2 = 1-10nF/25V 0603 (auchtung am strom spitze als DCC signal - zu prufen strom am dioden D1-4)
R5 = 10kOhm 0402 pull-up
CAM = kamera+funk 5V/100-150mA
Q2 = N-ch MOS SOT323
Q1 = P-ch MOS SOT323
R3 = 10kOhm 0402 pull-up
D7-8 = 2-3 normal oder ein zener diode 0603 (spannung Udiode78 = Ur1+Ube, Ube=~0.7V)
R1 = 3-5ohm zu stellen laden strom am akku (konstante Ur1/R1=laden strom)
Q3 = PNP SOT23 (max leistung = laden strom + spitze beginen 5V spannung, normal leistung 1/2 von max)
R2 = 10kOhm 0402 zu aktivieren PNP
D5 = Entladen auf Kamera (beginnen 5V-Udiode5, bis 3.3V min spannug kamera)
zwischen draht C3 und CAM ist moglich noch ein 200mA sicherung. Max strom sicherung fur eingang dioden ist bereits gemacht mit MC34063 richtige Berechnung
Danke für die Informationen!
