![MDVR - Modellbahn Digital Versand Radtke](https://www.1zu160.net/images/promotion/MDVR-Decoder2019.gif)
THEMA: Making Bobina CSD E499.1 loco from MiniTrix E40
Painted as Che-Es-3 MPS USSR
Body and trucks were drawn on SolidWorks and 3D-rrinted
MiniTrix E40 chasis remastered.
Model has:
1) No traction tyres.
2) Each Wheel and truck springing.
3) Twiced wheel contact.
4) Coreless maxon motor .
5) Closed crank cases.
6) PowerPack.
7) Weight 130gramm.
8) Sound .
9) Train/single/shunting mode of lights with main light separately.
10) 2 LocoUncouplers.
Layout ride: https://youtu.be/mtXMIsIa1ik
Uncouplers and lights: https://youtu.be/p1PIr3K0epk
Springing: https://youtu.be/G8-sRP6pkm8
Die von Vadim zu diesem Beitrag angefügten Bilder können nur von registrierten Usern gesehen werden - Login
Absolutely great. Congretulations for this excellent Bobina.
very very nice and good Job
![](emo/-).png)
what kind of dcc controller do you have for all the functions and mapping?
what dcc controller did you use for all the functions and mapping of the bobina ?
What did you print the case with ?
greetings heinz
Your work is absolutely excellent! Thanks for sharing with us!
Helpful and interesting to see how you made the windows. The only little downside are the pantographs, which look so much like the well known mass production parts. But I don't know anything about the prototype pantographs.
Like to see more of your work
![](emo/,-).png)
Best wishes
This is some crazy, extraordinary craftsmanship! 130g in this size! There is almost no Minitrix-loco left. Looking just at the electrical wiring! Is that an ESU Next18-Decoder where you removed the Next18-Socket and soldered directly to the pads?
And that self-built uncoupling-mechanism: ingenious! And finally someone, who sees, that springing wheels improves pickup significantly.
There ist one thing I must agree with Carsten, though: The pantographs are not on the same level as the rest of the loco. This masterpiece deserves something more fine.
Thanks for sharing!
Andi
I use old ESU LokSound micro decoders and LokProgrammer. LS4 or 5. LS 5 have more function outs, but works with powerpack by strange way.
I print it by my old chineese-bought fotopolymer 2K 3D printer (w resolution 47mkm per pixel at XY and 20mkm step per Z.), which was extreme home-modified by 395nm 200W UV source and rigid astronomically grade precise Z positioneer. I used professional resin from perfactory Aureus printers.
I CNC it from CD slim pack H=1.1 mm
I use 3 phase DCC signal use 2 rails and contact wire of working catenary in aim to get stable E-pickup.
Demo: https://youtu.be/iRsDl_j2cSI
So, i need stable rigid panto.
I use pantos from MiniTrix E40 donor of chasis.
Yes, i use Pb in every places where i can put it! Aim - to remove traction tyres and get enough power to pull long trains. Another aim - stable E-pickup. Also i ve installed powerpack.
Yes. ESU LS5 decoders - all have very high NEXT 18 harness. It's unapplicable for very low-height locos.
I cut its cap off by thin diamond disk, then, remove pin by pin unsoldering it, and use thin PTFE wires.
It's right! Also, springing trucks allow us to remove unspringed mass, and loco runs quiet. There is no sound effett of pulling brick along plywood.
thats an excellent work! Super. Thanks for the video!
Can You advice a link to CSD N-Scale forum of Czech Railroad Modelling ?
here you have a link: http://diskuze.modely.biz/index.php
But I don't think anyone in the Czech Republic is interested in a Russian Bobina. There are Czech bobinas in gauge N.
I have 5 Bobinas of the CD and CSD by myself.
S pozdravem
Heidi
Andras
Thanks a lot!
I mean Bobina - as a class, or as an example of sufficiently small loco, which difficult to make workable at automatishe layout.
Locos which have a small number of axles (4 or, even, less) have high probability to get a stall due to bad contact (dust, oxydations...), and there are a big broblemm to make them obidient. Especially, it is important for realistic smoth acceleration and braking when loco slightly moves via turnouts.
There are different way to get it ( use accumulators and wireless communications (IR or WiFi) ) but LiPo flat Accumulators dont fit (because full discharge will destroy it), and NiMH is not so small and flat to fit for N-Scale. Also, there are no decoders which will collectly work with it. So, the best way remains using of different capacitor power packs and electrical pickup improvements (springing, twice contacts et al). Also, USP and UPS processing helps, like read commands via isolator (Like LENZ Gold + has). But LENZ -is not sound decoder, and sound decoders have not these abilities, and problem still remains...
You have a g00d looking Bobinas, Please tell, how you solve the problemm of it's stable working?
My Bobinas are from TH Model and have been converted to coreless motors with a flywheel. They don't have traction tyres, but they have very good traction forces. My models are analogue and drive without problems.
S pozdravem
Heidi
Zitat - Antwort-Nr.: 9 | Name: Andras
Aber Vadims ist hübscher als die von TH Model.
Das liegt immer im Auge des Betrachters. Ohne Zweifel ist die Bobina von Vladim ein sehr sauber gearbeitetes Modell, aber wenn ich Vladim richtig verstehe hat er Probleme mit einem sicheren Betrieb. Diese Probleme habe ich nicht!
Abgesehen davon, passt das Modell von Vladim nicht zu meinem Anlagenthema. Einen anderen Hersteller von akzeptablen Bobina´s der CD bzw CSD, ausser TH Model, kenne ich leider nicht und da gilt dann besser eine halbwegs akzeptable Bobina als keine Bobina
![](emo/,-).png)
Gruß aus Südmähren
Heidi
to HEIDI / My Bobinas are from TH Model and have been converted to coreless motors with a flywheel. They don't have traction tyres, but they have very good traction forces. My models are analogue and drive without problems.
Yes, analogue power allow to get more stable run (with other equal conditions) because having a DC instead AC (DCC) do not exclude inuctivity of motor and power-supply from rail circuitry. Inductivity will support current during disruptions of electrical contact on a dust. At DCC motor inductance is mooved behind rectifyer and do not participate in rail circuitry.
If you would put a DCC decoder in Your loco, not changing or adding any other things, run quality will become noticeably less stable.
DC has excellent run stability, newertheless it does not have additional function control. As to me, i need functional work, so, i was forced to use DCC.
Gruß aus Südmähren
Heidi
Please do not worry about it. One can get, or print, or paint any new body and wear on chassis.
The main attention of my post is devoted to "How make stable run for short and little axled locomotive models"
I tried to paint my bobina's body 5 times, spending about 1 week of time, all evenings after work. Only last variant became to have applicable look. Minor errors also exists, but I do not decide to further lick out this model.
bin ich hier in einem englischsprachigem Forum gelandet?
Dachte immer 1zu160 sei deutschsprachig!
jetzt ist es mal ein EIN thread (unter tausenden), indem überwiegend englich geschrieben wird, weil das Mitglied aus Russland kommt und scho wird gemault...
"kopfschüttelnd"
Werner D.
PS @Klaus auch beim Übersetzen ist google dein Freund https://translate.google.de/?hl=de
![](emo/-).png)
da hast Du ein sehr schönes Modell gebaut, keine Frage.
Ich finde auch die vielen Zusatzfunktionen und Spielereien sehr schön. So etwas liebe ich.
Was ich trotzdem nicht verstehe, ist die Vollfederung:
So eine Drehgestell-Lok ist ein Standard der Großserienhersteller und auch per se nicht wirklich schwierig in der Stromaufnahme: Jedes Drehgestell ist schwenkbar aufgehängt und richtet sich auf dem Gleis aus. Der Achsstand des Drehgestells ist relativ kurz, das begrenzt den Nutzen einer gefederten oder kippbaren Achse sehr. Wenn die Federn ein- und ausfedern können, müsste das am Lokgewicht ausgerichtet werden. Wenn die Achsen in der Lagerschale aufliegen, gleichen die Federn evtl. einen Schienenstoß nach unten aus. Insgesamt riecht das nach viel Fummelei, mit der man durchaus mehr Probleme schaffen kann, als man löst. Sehe ich das so falsch?
Ich würde das also nicht unbedingt nachbauen wollen.
Deine Gleise sehen im Video sehr akkurat verlegt aus, gerade, geputzt und mit polarisierten Weichen. Die Kondensatoren sollten über verbleibende Lücken helfen.
Ich finde den Gedanken, "ich hab es gemacht, weil ich es kann und weil ich es wollte" voll in Ordnung und schaue mir das auch gerne an. Vielleicht lerne auch etwas dazu. Immer gern....
Es grüßt
ty zdelal ochen slozhnuju rabotu!
Ochen interessno i ochen krasivo!
Ja v vostorge!
Poka!
Ingolf
P.S.:
Hallo Vadim,
du hast eine sehr komplizierte Arbeit vollbracht!
Sehr interessant und sehr schön!
Ich bin begeistert!
Tschüss!
Ingolf
Zitat - Antwort-Nr.: 19 | Name: Dietrich
Did you calculate the "amount" of energy, that can be saved in those inductors? You will see, that there is NO real effect of "helping the motor".
---------DE-----------
Hallo Dietrich!
Der Gleichstromeffekt eines stabileren Laufs ist nicht in gespeicherter Energie, Motorinduktivität und Stromversorgungsdrossel, sondern erscheint als Wiederherstellungskontakt durch den Luftspalt zwischen Rad und Schiene in der Nähe von Staubobjekten, auf denen sich das Rad in diesem Moment befindet. Wie wir bereits aus der Schulphysik wissen, versucht die Induktivität, einen konstanten Strom zu unterstützen, wenn sich der Widerstand ändert, aber die Spannung kann sich vorübergehend ändern und extrem hoch sein. Ein Beispiel: Als ich ein Kind war, gab es in der UdSSR kein Kinderspielzeug. Ich habe Quecksilberlampen in einem Müll gefunden und parallel an eine 4,5-V-Batterie angeschlossen. Wenn ich den Kontakt unterbreche, entsteht ein großer Bogen und ich kann sogar einen Hochspannungsschock bekommen! Wirklich alles aus 4,5V Akku!
---------Eng-----------
Hello Dietrich!
The DC effect of more stable run is not in stored energy an motor inductivity and power supply choke, but it appears as restorinc contact through air gap between wheel and rail near dust object on which wheel stay at this moment. As we allready known from school physics, inductance try to support constant current when iresistance is changing, but voltage can change momentary and can be extremely high. An exampe : When i was a child, there were no child toys in USSR. I found mercury lamp choces at a garbages and connect it to 4.5V battery in parallel. when i disrupt contact a big arch appears and i can even get high voltage shock! Really all from 4.5V battery!
------------DE------------
Entschuldigung für Englisch. Jetzt tippe ich zuerst deutch ein und bleibe anso EN-Text zur Kontrolle. Ich kann den deutschen Text nach dem Übersetzer nicht überprüfen. Es kann oft falsch übersetzt werden.
------------EN------------
Sorry me for English. Now i will type deutch first and will remain anso EN text for control. I cannot verify deutch text after translator. It can often translate incorrect.
Zitat - Antwort-Nr.: 20 | Name:
gusbajer
-------------DE--------------
Die wichtigsten Orte, an denen die Strecke nicht so flach ist und die Lokomotive die kleinste Geschwindigkeit hat, sind Weichen. Versuchen Sie, das original minitrix E40 DCC-Modell mit langsamer Geschwindigkeit zu betreiben. 90% wird es beim Weichenfrosch stehen bleiben!
Original MiniTRIX-Modelle haben keine gefederten Achsen und Räder und keinen Neigungsfreiheitsgrad für eine Achse (wie z. B. Roco BR101)
Also, zum Beispiel auf der Weiche: Der erste LKW wird auf 3 Punkten stützen, die die Ebene (aus der Geometrie) definieren. Daher haben wir nur eine Achse in Kontakt mit Schienen. Darüber hinaus wird die Lokomotive leicht geneigt sein, da Frosch und Schnurrhaare nicht in einer flachen Ebene liegen. Sogar 5 Mikrometer reichen aus, um Kontakte zu unterbrechen.
Zweiter LKW kann an Schienen leicht geneigt sein und nur von einer Seite berühren (keine Neigungsfreiheit).
Ich habe ein 8-Kanal-Oszilloskop bekommen und alle Radkontakte getrennt und alle Radströme gleichzeitig gemessen. Nur 3 Achsen haben Strom. Sie können sich während der Bewegung schnell austauschen, aber nur 3. Gefedertes Modell hane Strom durch alle Radkontakte und nur Staub verursacht Störungen in Stromdiagrammen.
Wie ich geschrieben habe, funktioniert dieser Effekt dramatisch nur bei DCC. Bei Gleichstrom werden Sie viele Spannungsunterbrechungen sehen, aber der Strom wird aufgrund der Induktivitätsüberwölbung bei Unterbrechungen, die den Kontakt wiederherstellen, ungefähr konstant sein.
Der Unterschied zwischen 4 und 3 metallischen Achsen ist dramatisch. Stehwahrscheinlichkeit der Lokomotive bei einer Achse mit Haftreifen - steigt dramatisch an. Es lohnt sich also, dieses Aufhebens um die Federung zu machen, insbesondere bei kurzachsigen Lokomotiven, wenn Sie eine realistische Eisenbahnmodellierung mit automatischem Layout haben, wenn die Modelle reibungslose Bewegungen haben.
Ich benutze Metallkränze, um Lokstände an Weichen zu vermindern, neuerdings bleibt es ein guter Platz für einen Stellplatz. Die Strecke ist nicht ideal flach, und wir haben Staub.
Eine andere Sache - Kontaktverlust, wenn die Lok angehalten wird. Es scheint unglaublich, aber es passiert oft.
Sie können Lenz Gold + Decoder verwenden, um dieses Problem zu lösen. Sie spüren Kontaktverlust und leichtes Bewegen durch Motoren, um guten Kontakt zu suchen. Aber sie haben keinen Ton. Sounddecoder haben keine USP- und USV-Features (nur Netzteil und funktionieren nicht so optimal). Da hilft nur Federn.
Signifikante Verbesserung - macht 3-Phasen-DCC-Oberleitung (wie ich es benutze). Aber nicht alle Decoder funktionieren damit. Jemand kann Staub fälschlicherweise als seltsamen Befehl erkennen und stoppt bedingungslos, obwohl der Strom eingeschaltet ist. (als ABS oder HLU oder anderes Signal, obwohl sie bei CV abgeschaltet sind)
Drittes Problem - selbst wenn Sie eine 100-achsige Lok haben, kann der erste LKW den Kontakt verlieren, wenn Sie an einem kurzen isolierten Blockabschnitt bleiben. Es ist nicht so gut für Rangierautomaten. Zum Beispiel. Loks mit gefederten Achsen haben diesen Nachteil nicht. Ich hatte eine 8-achsige 2-teilige Lok. Oft wurde es nur beim letzten LKW angetrieben und verlor den Kontakt von 3 LKWs aus einem kurzen Rangierblockabschnitt. Nach dem Springen trat kein solcher Effekt auf.
Was die Federung angeht:
Zusammenfassend muss die maximale Spannung der Radfedern um die Hälfte schwächer als das Gewicht der Lokomotive sein. Es ermöglicht ein ausreichendes Spiel aller Räder (an Herzstücken, Schnurrhaaren ...), und sie bleiben in Kontakt.
Zusammenfassend muss die maximale Spannung der Drehgestellfedern 2 Gewichten der Lokomotive entsprechen, damit kein Bugelkontakt auftritt und die ungefederte Lokomotivmasse von den Drehgestellen getrennt bleibt. Es ermöglicht nicht nur Neigungswinkelfreiheit aller Trucks, sondern auch sanften Lauf auf Sperrholz.
-------------EN--------------
Main places where track not so flat, and Locomotive has the smallest speed - is turnouts. Try to run original minitrix E40 DCC model at slow speed. 90% it will stall at turnouts frog!
Original MiniTRIX model have not springes trucks and wheels, and have not tilt degree of freedom for one truck (As in Roco BR101, for example)
So, on Turnout, for example: first truck will support on 3 points which define plane(from Geometry). Therefore we have only one axle in contact with rails. Moreover, locomotive will have slightly tilt because frog and whiskers is not in flat plane. Even 5 micron enough to disrupt contacts.
Second truck can be slightly declined at rails and can contact only by one side (no tilt degree freedom).
I got 8-channel oscilloscoppe and separated all wheel electrical contacts and measured all wheel currents simultaneously. Only 3 axle havd current. They can fastly exchanges during motion , but only 3. Springed model hane current through all wheel contacts and only dust make a gliches on current graphs.
As i wrote, this effects drammatically works only at DCC. At DC You will see a lot of voltage disrupts but current will be approximately constant due to inductance arching at disrupts, which revert contact.
The difference between 4 and 3 metllic axles - is drammatical. Probability of locomotive stalls when one axle with traction tyres - drammatically rises. So, it is worth to make this fuss with springing, especially for short-axles locomotives, when you have realistic railroad modelling automatic layout when models have smooth movements.
I use metall frogs to diminish locomotive stalls at turnouts, newertheless it's remains a good places for stalls. Track is not ideally flat, and we have a dust.
Another thing - loosing contact when loco is stopped. It seems incredibly, but it often happens.
You can use Lenz Gold + decoders to solve this problem. They sense contact loosing, and slightly mooving by motors, seeking good contact. But, they have not Sound. Sound decoders have not USP and UPS features (only powerpack and work not so optimally). Only springing will help.
Significant improvement - is making 3 phase DCC catenary.(as i use). But not all decoders will work with it. Someone can mis detect dust as a strange command and will unconditionally stop, althoug power is on. (as ABS or HLU or other signal, although they are shut off at CV)
Third problem - even You have a 100 axle loco, first truck, staying at short isolated block section can loose contact. It's not so good for shunting automatics. For example. locos with springed axles have no such disadvantage. I had 8 axle 2 section loco. Often, it was powered only at last truck, loosing contact by 3 trucks from short shunting block-section. After springing no such effect appeared.
As to springing:
Summary maximal tension of wheel springs must be a half weaker than locomotive weight. It allow a enough backlash of all wheels (at frogs, whiskers...), and they will remain at contact.
Summary maximal tension of truck springs must equal 2 weigts of locomotive, so, no bugel contact occurs, and nonspringed locomotive mass remains separated from trucks. It allow not only tilt angle freedom all trucks but also smooth quiet run on plywood.
Danke Ingolf! Ich versuche immer noch, etwas zu erfinden, um eine gute Modellierung der Lokomotivbewegung zu haben.
--------En-----------
Thanks, Ingolf ! I Still trying to invent somewhat to have a good modelling of locomotive motion.
Zitat - Antwort-Nr.: 22 | Name: Vadim
The DC effect of more stable run is not in stored energy in motor inductivity and power supply choke, but it appears as restoring contact through air gap between wheel and rail near dust object on which wheel stay at this moment.
As we already know from school physics, inductance tries to support constant current when resistance is changing, but voltage can change momentary and can be extremely high.
You mention physical effects that really exist, but I can assure you - I have studied electrotechnics - these effects will not appear with those small inductors.
Four-axled (BoBo) locomotives: I have many of those. NONE will stop on an insulated frog. If it does, something is broken (wire, contact sproing, ...) and will be fixed. Or the wheels are full with dirt and need cleaning. However this type of locomotive is really very reliable and needs no modifications.
By the way, do you know ATF (automatic transmission fluid)? It improved the contact "friendliness" of my tracks significantly. Maybe you should try it. There are some threads in this forum.
![](emo/-).png)
die ersten 2 guten Ratschläge, die ich so entnehmen kann:
- nimm keine Minitrix E40 als Basis für eigene Selbstbau-Modelle
- kümmere Dich um Dein Gleis.
![](emo/,-).png)
Ich hab wie Dietrich kein Problem bei BoBo-Loks, wollte aber auch nie eine Lok bauen, die über die Schienen "schwebt".
Dass stets nur 3 Räder am Gleis sind, ist ganz natürlich und (fast) immer so.
Wenn davon 2 Haftreifen sind, ist das Pech, das Problem muss dann das 2. Drehgestell retten.
Oder ich schaffe die Gummiringe ab und lade das Modell mit Blei voll.
Soweit hast Du das konsequent umgesetzt. Sehr schön!
Ich habe ein paar Loks, die ein Fahrgestell benötigen und ich wollte diese selbst bauen.
Vielleicht versuche ich mal bei einer Lok, Deinen Ansatz aufzugreifen.
Das ganze Drehgestell zu federn, sollte nicht zu schwierig sein, danke für Deinen Rat hierzu.
Im Prinzip müsste es reichen, nur eine Achse im Drehgestell pendelnd aufzuhängen und zu federn.
Im Video sieht man so gut wie gar nicht. wie Du das gemacht hast. Hättest Du Lust, hierzu mehr zu sagen und zu zeigen?
Danke und Grüße
(Google translator is not the best. Und Hartmut: Du liegst m.E. falsch)
... the first 2 good pieces of advice I can take from this:
- do not take a RTR Minitrix E40 as a donor for your own DIY models
- take care of your track.
![](emo/,-).png)
Like Dietrich, I have no problem with BoBo locomotives, but I also never wanted to build a locomotive that "floats" over the rails.
The fact that there are always only 3 wheels on the track is quite natural and (almost) always so.
If 2 of them are rubber tires, that's bad luck, the problem then has to be solved by the 2nd bogie.
Or I´d remove the rubber rings and would stuff the model with lead.
So far, you have consistently implemented this. Well done!
I have a few locomotives that will need a chassis and I wanted to build these by myself.
Maybe I'll try to take up your approach with one of these locomotives.
Springing the whole pivoted bogies should not be too difficult, thank you for your advice on this.
In principle, it should be sufficient to spring one single axle in the bogie and letting it pivot in cross direction.
What do you think?
In the video I could hardly see how it works and how you did it. Would you like to say and show more about this?
Thanks & cheers
Zitat - Antwort-Nr.: 26 | Name:
iomegale
Thanks, Hartmut ! Oligarhs is trying to confront us, but we must remain human.
Zitat - Antwort-Nr.: 27 | Name: Dietrich M.
This is more a "believing" effect than a physical one. Truely you NEED energy, to have an effect. These SMALL inductors, installed to block HF disturbances from the collector fire, do NOT have an effect on motor run.
DC more exposed for arch stabilizing, than AC. Inductance of motor is sufficient to set fire to the arc. This inductance is extremely big with comparison of measured inductance when you insert a DCC decoder, and motor becomes isolated outside the rectifier and stop playing its role.
If you do not believe to radioelectronics, run short number of axles DC model(where motor is directly on wheels). then, insert a standart decoder without power pack, and run again - feel the difference! How can you explain it?
And we also know "from school physics", that this effect uses the stored energy in the inductor. .
Locomotive does not need inductance energy. It only allow to get electrical Arc. Arc restore contact wheel-rail, because it have low resistance. So, there is no electrical current disruptions and Locomotive continue run. On the contrary, No arc in DCC appears while contact disruption occurs. Locomotive stops.
Do You have Bobinas with DCC decorers or DC intact locos ? This question define a big difference of approaches to get good run.
as to automatic transmission fluid concern - any fluid will accumulate dust on it. (Remember No-Ox, et al). So, as a result - with time, all these dust in mixture ti this liquid will be as plastilin, and will wire on to wheels.
All my axles are excellently clear all the time and does not accumulate any plastilin. I use Isopropanol swab car and vacuum car to get my rails absolutely oil-free. Do not touch rails by hands. All Organic material with time will be transformed to plastilin on wheels. It is my experimental experience to good run on DCC.
Zitat - Antwort-Nr.: 28 | Name: gusbajer
Hello Klaus. I recomend to spring both trucks, it will remove unspringed mass of chassis. Also you get more degree of freedom of truck to track adoption.
I mill it at CNC spring from Ni-Mo thin foil for springs, and mill at hand miller nest for it at MiniTrix E40.
Then i screw it by 1mm DIN screws. See the Photos. Also i add photo for Brawa Ludmila truck springs. It's easy and one can do it at 5 minutes.
There are many other means to do it. By round or by flat springs.
Zitat - Antwort-Nr.: 30 | Name: Vadim
Do You have Bobinas with DCC decoders or DC locos ? This question defines a big difference of approaches to get good run.
![](emo/-).png)
Bad examples are Minitrix steam locos of the "new design principle" (core-less motor in the boiler). The ones I have and know (S3/6, Br45, G12) have all driven and tender wheels for pickup, but the wheels are stiff in the frame. As a result the pickup is poor for so many pickups. Worst of them: Br45 which has (theoretically) 14 Wheels for pickup. You can improve that model significanty by removing some plastic-pins in the base cover of the tender. The pickup-sheet than acts as a spring for the axle.
Also a big error I noticed: lit passenger coaches. When the light flickers, some people increase the pressure of the spring-sheet-metal to the axle. They believe, the contact between spring and axle is the problem. As a result, the coach has increased drag and the spring is so strong, that there is no springing effect left. the result is worse than before.
Btw: by very, very far my model with best pickup is my modified Br61: all wheels with individual pickup, two sprung bogies, sprung driving wheels. There is almost no track dirty enough. capacitors obsolete. In addition: when coupled with its train, there is also pickup in the coaches and current transmitting couplers.
see here:
https://www.1zu160.net/scripte/forum/forum_show.php?id=1232713#aw9
Andi
for ideas, info and photos.
It will not be my next project, but I will make a heavy sprung loco.
This sounds like fun at tinkering.
Possibly not with the same means due to differing basis.
cheers
Zitat - Antwort-Nr.: 32 | Name: Dietrich M.
I have operated my locos for several decades with DC and now since roughly ten years with DCC. In all cases my locos ran without a problem on the insulated frogs.
Do You have some video about Run? Different people have a quite different Concept of good run . My concept - Loco must run as the first speed (extra slow, approaching speed in auto layout) around all layout without any stalls.
It seems, that you have not read or understood the usage of ATF. You only need such an incredibly small amount of ATF, that the effect, expected by you, will not happen. Put TWO DROPS of ATF on a piece of cotton and apply it to FIVE CENTIMETRES of your track once a month. Thats all and IT WORKS.
my layout is placed in room whwew i live. There are a lot of dust (from clothers and other tissues). So, any hydrophobit liquid will attract dust, so, all of them will be wind up into wheels and becomes as blue plastilin. I tried a lon of different kind so strange approaches with liquids, but all of them led to wheel plastification. Only one idea works: Dry rails by isdopropanol and vacuuming. Do not touch it by hands. So, layout can run some months without any cleaning, and dry dust is accumulating at trucks near wheels as a santa claus beards, but wheels and rails remains absolutely clear
![](emo/-).png)
You can try to explain again about ATF in more detail. I finally do not understand it.
Zitat - Antwort-Nr.: 33 | Name: DerEine
Hello Andi. I see You re fully understud all advantages of wheel/truck springing.
About stable cab light in passenger railroad cars.
You can see my run of 8 passenger car train at first message of this thread. Each wagon equipped by it's own light decoder, No wires between cars. + small 200mkf powerPack and current stabilizer (essential element). It stabilize current into LEDS if powerppack voltage will fall. No any blinking effect at all! Electricval current pickup from all wheels at a needles (all 4 left+all 4 right) I ve got it from KATO trucks). left and right needles are isolated by plastic sleeve.
It's really works! And excellent no friction run. A small Bobina without traction tyres can pull 8 cars (each 40gramm) at slope 2.5 cm per 1meter!
As to steam locomotive concerns - i allready have a big pain with simply quadratish diesel and electric loco models, it must be all axle drive and easy to open for regulations. When i see a steam loco - i cannot understand how it can be safely taken by hands without loss of small elements. Another pain - full drive and how to insert uncouplers.
Andi
(eine arnold br01.5 und eine trix 52.80)
I have used 2 times the zimo staco1 in 2 steamlocomotives. And power pickup is just not a factor anymore. They drive with full sound for at least 5 seconds.
The only disadvantage is that of course without rail contact that they can not be controlled.
Furthermore I really think you did an amazing job with this complete redesign. Especially the springed bogies and even more the axles.
I'm not discussing the need of doing this. But if we remember the older minitrix locomotives from the 80s. They also had a copper springplate between the chassis and bogies.
Regards Joost.
Ein neues Leben stabiler DCC-Läufe für kurze Lokomotiven ist jetzt verfügbar, indem der Ansatz der Schwerlast durch Gießen des Körpers aus Messing genutzt wird.
Jetzt habe ich einige Testmuster bekommen.
Sie haben einige kleine Defekte und Hohlräume, sind aber für den Testeinsatz geeignet.
Etwa 50 Gramm Modellaufbaugewicht sind für Lokomotiven ohne Haftreifen nicht so extra.
Es hilft den Rädern, den Staub zu glätten, um die elektrischen Räder mit den Schienen zu berühren und die Zugkraft zu verbessern.
Was die tatsächliche Radfederung betrifft - siehe KATO SD40 gen3-Lokomotive, bei der einige Achsen und alle Lastwagen gefedert sind.
Also, ich meine, die Autorität von KATO USA wird alle Diskussionen gegen Radfederungsaktivitäten unter Eisenbahnmodellbauern beenden.
=====EN=====
A new life of stable DCC run for short locomotives is awailable now using approach of it's heavying using casting it's body from brass.
Now i му got some test samples.
They have some small defects and cavityes, but is applicable for test use.
About 50 gramm of model body weight do not be as extra for locomotive without traction tyres.
It helps wheels to flattened down the dust in aim to touch electrically wheels to rails and improve pulling force.
As to wheel-springing actuality - see KATO SD40 gen3 loco where some axles and all trucks are springed up.
So, I mean authority of KATO USA will close all discussion against wheel-springing activity among railroad modellers.
