THEMA: Fleischmann br 602 (7770001)manufacturing errors
Mr.Bean - 22.01.24 18:19
Hello,
I come from China, I am very happy to communicate here.
I purchased a set of Fleischmann BR 602. However, I found an error. On the document, which clearly indicates that the electrical coupling is located on the 901 203-0 car. In reality, the electrical coupling is on the 901 106-5 car. This will cause the vehicles to be unable to couple correctly. Has anyone else encountered this issue?
Thank you!
Die von Mr.Bean zu diesem Beitrag angefügten Bilder können nur von registrierten Usern gesehen werden - Login
Hier dieÜbersetzung :
Ich komme aus China, ich bin sehr glücklich, hier zu kommunizieren.
Ich habe einen Satz Fleischmann BR 602 gekauft. Ich habe jedoch einen Fehler gefunden. Auf dem Dokument, das deutlich anzeigt, dass sich die elektrische Kupplung am Auto 901 203-0 befindet. In Wirklichkeit ist die elektrische Kupplung auf dem 901 106-5 Auto. Dies führt dazu, dass die Fahrzeuge nicht in der Lage sind, richtig zu koppeln. Ist noch jemand auf dieses Problem gestoßen?
Leider hab ich den Triebzug nicht.
Gerald
Hello Mr. Bean,
you are obviously right that Fleischmann made a mistake by causing a difference between the printed instruction sheet and model assembling.
But in reality there happened several changes in lashing up the passanger coaches between the motor cars.
So you just should connect the electrical coupling to the motorized car and exchange the cars you mention by number.
And then have fun with this amazing train!
Regards
Hello,Karl
Thanks for your reply, but this would lead to differences with the actual vehicle.
Hello Mr. Bean,
i had the same problem. Put the coach with the elecrtical coupler with this coupler to the motorized car. I do it this way and i have no problems in this case with this train.
The instruction is not correct.
But do you know that there is another problem with this trainset? They put in two restaurant coaches but no bar coach. As i know Fleischmann will fix this. So contact your dealer about this fact.
https://www.1zu160.net/scripte/forum/forum_show.php?id=1383984&start=9#aw25
Gruß, Oli
Hello Oil,
I am aware of this issue, have sent an email to fleischmann, and are tracking the situation. Thank you for your reminder.
Regards
Bean
Hello,
thanks for the photographs, Mr. Bean.
Besides the other topics the inaccurate painting / printing of your coaches are a little underwhelming: On one coach (901 106) the red area includes the frame, on the other coach (901 203) the red area ends with the chassis. I wonder, how these two coaches look like when coupled together. How does the other coaches are painted? Could you provide more pictures?
Regards,
Hallo GemeiNde,
Ich hole mal diesen älteren Fred wieder hervor. Meine Frage betrifft allerdings die analoge Variante mit der Artikelnummer 776001. Ich überlege mir derzeit, dieses Modell zu erwerben.  Hat zufällig jemand den Triebzug bereits und kann mir sagen, ob die Wagen jetzt richtig ausgeliefert werden? Eine Nachfrage bei Kramm vor einigen Wochen wurde leider bislang nicht beantwortet.
Viele Grüße und ein frohes Osterfest wünscht
Albert
Hallo Albert,
ich kann dir nicht sagen, ob die aktuell ausgelieferten Triebzüge mit den korrekten Wagen ausgeliefert werden. Ich jedenfalls habe heute den korrekten Barwagen ohne Türen vom Händler meines Vertrauens erhalten.
Du kannst das Set getrost kaufen, da du ggf. vermutlich rasch den richtigen Barwagen erhälst.
Grüße - Werner P
Hallo Werner,
vielen Dank für die Info. Ich hatte schon gar nicht mehr mit einer Antwort gerechnet. Dann werde ich mir wohl in nächster Zeit etwas "gönnen"😀.
Viele Grüße, Albert
Hallo Albert,
ja, gönne ihn dir! Aber höre dir vorher das Fahrgeräusch genau an. Sven Nikolaus hat bei YouTube eine Vorstellung des Modells mit Sound eingestellt.
Grüße  - Werner P
Hallo Werner,
danke für den Hinweis. Ich kenne das Video von Sven. Für mich kommt aber ohnehin nur die analoge Variante infrage.
Viele Grüße, Albert
