THEMA: ES 64 F4 Veolia Design
chrisb - 16.06.08 21:07
Hallo alles,
Ich bin zu dieser Gruppe neu und bitte um Ihr Verständnis, da Deutscher nicht meine erste Sprache ist.
ich habe eine Extralok ES-64 F4 von Minitrix, die ich in eine Veolia Version ändern möchte. Kann jedes mir mit den Farben für dieses lok helfen? Ich suche der grauen Farbe (RAL?) für die Seite, und der farbe fuer das Dach. Also ist auch dir Frontesiete Vekehrsrot (RAL3020) oder eine andere Farbe?
Danke fuer Ihre Hilfe
MfG Aus Manchester ChrisB
Hi Chris,
ask Ziemon at railcolorforum:
http://www.railcolor.be/international/viewtopic.php?f=34&t=28
regards
Hi Chris
I don't think it's a problem to ask in english if it's easier for you.
regards
Björn
@1
sorry Chris,
I did not see, you already asked there.
Maybe this one can help:
http://www.veolia-cargo.com/
they should know.
Yes I asked Ziemon, but he did not have the information. I sent a mail tonight to Veolia directly so maybe they will answer.
If not I will try and match the colours myself from the photos etc.
I already made an SBB Cargo 474, but those colours were easy to match as they are RAL numbers.
Thanks for your help.
Chris.
Chris, check this colors...
Badger Model flex #16-39 Southern Pacific Letter Gray
Badger Model flex #16-37 Southern Pacific Scarlet Red
not 100% but close...
steve w.
edit: sprache angepasst
Beitrag editiert am 17. 06. 2008 23:26.
Chris I have checked the company colors of  Veolia:
red is Pantone 485 C (L*a*b* = 50/70/57)
which is close to RAL 3024 (L*a*b*= 52/76/68) +b is more yellow , +a is more red,+ L is more light.
Grey Veolia Text may be Pantone Cool Gray 9C similar to RAL 9007, but for gray i have just the RGB values.
Thanks to everyone for their input on this topic.
I now have enough to start work on this project. Maybe I will post a photo when completed to show how it turns out.
Thanks
Chris.
Hallo Karl,
sind die Pantone-Farben  offiziele Veolia-Angaben oder hast Du die Informationen woanders her? Falls ich die Lok auch umlackiere hätte ich es so genau wie möglich!
Gruß  Christian
die Farbangaben stammen aus einem Veolia Frankreich PDF zur Information der Investoren. Es sind die Farben des Veolia Logos und der grauen Schrift darunter.
Man kann das mit entsprechenden Tools aus der Druckvorstufe analysieren.
Es ist schon seltsam, daß in den Firmenprospekten zu Investorrelations, die Firmenlogos als konkrete Pantonefarben angegeben werden, in den sonstigen Schreiben meist nur als Ersatz RGB Werte. Aber wahrscheinlich werden die Ersten mit
der ensprechen Publishing Software erzeugt und die anderen wie üblich mit Winword.
Ob die Loks auch wirklich in diesen Farben lackiert sind, entzieht sich meiner Kenntnis.
Wird Pantone überhaupt für solche Lackierungen oder Folien hergenommen?
Auf Nachfrage bei Veolia Deutschland zu der Lackierung ist leider bisher keine Antwort gekommen.
