THEMA: CRITICAL SLOPE=? Degrees(°) vs Percents(%)
Vadim - 09.10.09 15:45
Topic: CRITICAL SLOPE=?  Degrees(°) vs Percents(%)
Who think about  "which is the relations between Degrees and Percents of slope? "
I mean this approximation is true at small angles:
PERCENT = (Pi/2)*(100%/90deg) * DEG = 1.74*DEG
For example : 4 % slope = 2.3 deg. slope.
Is it right?
But what is recommended maximum angle for trains at layouts ?
Have you ever thought about it?
I remember, that someone  recommends on forumes that this value must be equal about "2"  but in DEGREES or in PERCENTS?
Namely, Is it  2 degrees or is it  2%?
It is different things, and It is critical to do a mistake!!!
Vadim
Hello Vadim,
as far as I know a maximum of 2% is recommended, especially if it is supposed to look realistic. I'm working with a maximum of 2%.
I guess as long as the trains aren't too long (let's say american road train dimensions...) steeper grades (slopes) should be possible as well.
I hope this helps,
Thanks, Jan.
But which smallest radius recommended for good running trains without derailments?
And which smallest radius seems to be realistic?
Vadim
Dear Vadim,
the formula is wrong.
Persent means  X m high per 100m way.
2% = 2 / 100 = 0,02 or
4% = 4 / 100 = 0,04.
And now you need the tan-1. (I mean the invert-tangent)
deg = tan-1(0,02) = 1,14
deg = tan-1(0,04) = 2,29
Best regards
Frank L.
Well Frank,
you just verified that this approximation is usable, although I don't know why you would need it ...
Cheers, Thomas
Giving Your result from atangences and dividing it we obtain  almost the same proportional coeficient, which i got:
2% / 1.14 = 1.754
Yes, it's only approximation.
Vadim
Hello Thomas, hello Vadim,
Oh... sorry
I have understand... ups
Frank L.
All Ok. Dont worry.
I also had  but a more serious mistake:
Initially i payed small attention to NMRA and believed that max. slope must be 2 deg but not 2%.
Now i m  fully remaking my layout....
Vadim.
