THEMA: RS clips of Lenz RuckMelder -> ???
Vadim - 16.03.10 14:57
Hello.
Lenz Ruckmelder and turnout decoder has RS contacts .
To what i must connect them?
May be there are RS -> s88 transcoder?
How to obtain occupancy information?
Thanks
Vadim
Thanks
Vadim
Hallo Vadim,
if you use the Lenz System youn can connect them to the R-S input of the Lenz Central. Then you can see the status of the turnout. I don't know whether it is possible to connect it to a s88 transcoder. I suggest it wouldn't be of any use.
Greatings
Friedhelm
Greatings
Friedhelm
Hello,
Lenz Rückmelder connect to the RS terminals on the back of a Lenz command station (LZxxx or LZVxxx, not supported by the Compact).
The RS bus protocol is proprietary but has been reverse-engineered:
http://www.der-moba.de/index.php/RS-R%C3%BCckmeldebus
There is no RS->s88 transcoder, although I hardly remember there is or at least was some s88->RS converter.
Regards, Peter W.
Regards, Peter W.
