THEMA: How to adjust TrainController5.5 for esu ECOS
Vadim - 22.12.10 17:19
Hello
I have TrainController 5.5 (PC programm)
But it havent ECOS station in hardware system choise menu.
How can i adjust this programm to run on ESU ECOS?
May be tere are any additional patch file exists?
Thanks,
Vadim.
Thanks,
Vadim.
Hi Vadim,
I'll translate your question for our german-only readers.
Vadim hat TrainController 5.5 auf seinem PC, hat aber in dem Auswahlmenu für die Zentrale keine ESU ECOS. Wie kann er das Programm mit seiner Zentrale zum Laufen bringen? Gibt's da evtl. irgendwelche zusätzlichen Treiber / Patches oder so?
Hallo Vadim,
Train Controller 5.5 is a rather old program. When I startet to use the Train Controller about 5 years ago I had TC 5.7.
I think the ECOS didn't exist then or didn't exist in the form of today. Perhaps you look at the Freiwald-Site http://www.freiwald.com/seiten/download.htm and load down TC 7.0. You can use it for test and have a look, if ECOS is listed in hardware choice menue.
Greetings
Friedhelm
Greetings
Friedhelm
Thanks, Friedhelm !
I know TrainController 7 and already tested it. It supports both ECOses, but it's very expensive programm.
I think, i ll use LI connector instead. This Lenz interface is supported by TC-5.
Vadim
Vadim
Hi Vadim,
please, ask the question in the TC-Forum (link see at #2). I am sure, you get a very quick answer from the specialists there.
Greetings
Greetings
Hello Christian .
Please type this direct link in reply message there.
I still cannot found it.
Vadim.
Vadim.
Hallo Vadim,
this is the english forum http://www.freiwald.com/forum/viewforum.php?f=1
Perhaps you must sign in first,
Greetings
Friedhelm
Greetings
Friedhelm
Thanks, Friedhelm .
