THEMA: Rissian N-Scale Diesel TE101 with Sound(Video
Vadim - 03.07.12 17:30
Hello.
Now i ve installed Sound into Russian loco  TE101.
This is german BR232 model from BRAWA.
There You can see how it sounnds:
http://www.youtube.com/watch?v=MYreWXg_WA8
Loco was equipped by ESU sound micro decoder and large PowerPack!
Loko was also equipped with low consuming effective coreless motor (10-20 mA ) in aim to lenghten powerpack life  with sounds when loco moving via dust area.
Loco was equipped with extra weight in aim to work without traction tires with the same pulling efficiency.
LoudSpeaker is placed at fuel tank and occupy all free space.
If You have questions, please ask it!
Vadim.
Hi Vadim,
very impressive and full sound.
BR.
Thanks, Olaf!
Vadim
Hi Vadim,
its verry nice to sea! You have made ligth in the motor room. Respect!
Is it posible, that you show us your RZD Passanger waggons?
Privet do russia
Steffen
Vadim,
its verry good, how you made the Piko cars. The ligth on the end of the train is real like in russia.
3 red ligths.
I like to drive with the train in russia
Steffen
Hi Vadim
Absolutely great !!!!!and very impressive!!!  Very good work.
Thanks, Steffen and Kurt for Your estimation!
Vadim
Hi Vadim,
how do you make the wheel springing? That's absolutely interesting!
BR.
Olaf, You can see all stages on my photo gallery:
http://fotki.yandex.ru/users/vadimav/album/119099/
Flat springs is too weak, and can be made from 0.03mm Berilluum Bronze.
If You have questions, please ask.
Vadim
Hi Vadim,
is this the "Faulhaber"- engine ?
Thanks for pictures !
Regards............Rainer
Yes, Rainer..
1) I was forced to change Lo Efficiency Factory-Default motor into Hi-Efficiency motor, because PowerPack capacity is fastly discharging with old motor where loco running on dust.
2) I also remove traction tires in aim to rich more stable electrical pickup with my all springed wheels.
Vadim
Hi Vadim,
sounds really good...
Carsten von 1001-digital
Thanks, Viele!
But there is no space now to instal Smog generator into BR232/132 :)
Vadim.
Hi Vadim,
SOUND is enough,  DIESEL-SMOG is not necessary !!    : - ))      ..............Rainer
Hi Vadim,
yeah! Smoke generator rulez. Try to install it!
BR.
I think, Smoke generators will require heating, and will eat a lot of DCC current!
By the way, how much does Smoke Generator eat from DCC?
Vadim.
Thanks, Olaf.
I discovered, that these smog generators eat a lot of current and will require often servicing !
I agree, It's not so convenient.
It was FaulHaber, Who made general "RULEZ" in this loco!!!  :)
Vadim
Hi Vadim,
generator no. 8 seems to be good. The current consumption is 100mA an it is very compact. The voltage is 16-22V, so it is suitable for digital.
In my opinion the current consumption is ok and not to high.
BR.
Thanks, Olaf, but I think,  that Smog-Generator must be connected directly to rail common, (not to common blue decoders pole), in aim to prevent fast discharge of PowerPack.
Vadim.
And another question:
Are there schwartz or blue  smog liquid exists for diesel smog emulation?
Vadim
Hi Vadim,
*hehe* You thinking about to us it, are you?
Sorry, but I do not know, if there is a special smog liqiud.
If you find space, you can try to switch on and of with transistor or relay. So you can directly connect to rails.
BR.
I think, it must look as real Russian diesel train, like on this video:
http://www.youtube.com/watch?feature=fvwrel&v=trKF55sy6EI
Vadim
And here an other russian diesel train.
http://www.youtube.com/watch?NR=1&feature=endscreen&v=7Xn7SO8NVpY
Jörg
Yes! Russians love long trains.
In Moscow we have circle road which links all 9 railroad stations. It's diesel only road.
Usually, train lasts up to 60-80 cars.  It uses only 2*M62 [ 2*( Class 120 DR )] diesels.
VIDEO:
http://www.youtube.com/watch?v=QXKrD4DXOz8
At electric railroads we use VL class freight locomotives.
Vadim
Servus Vadim,
show me your other rissian N-scale Diesel, please !    :- )) .....................Thanks Rainer
Hello, Rainer.
I have only RS-2, BR232 and Class 120 DR diesels N-Scale models, which represents Russian TM2,  TE101 and M62.
Only one loco with sound now, which was represent here.
Other slill works without sound.
M62 Capital Repair  GALLERY:
http://fotki.yandex.ru/users/vadimav/album/123697/
TE101 Capital Repair Gallery:
RS-2 capital repair GALLERY:
http://fotki.yandex.ru/users/vadimav/album/125846/
Also I have Vt 12.5 Class 612 DB  diesel train:
You can see it only at this photo:
http://img-fotki.yandex.ru/get/5302/vadimav.6/0_555b6_4f34f359_XL
This is very poor quality Arnold model.
Vadim
Hello again!
There are some new sounds, implemented into N-Scale  BR232/TE101:
1) Russian typhoons.
2) Coupling clank at start.
3) Flange squeal.
http://www.youtube.com/watch?v=_KuHBUwnHB0
Vadim
