THEMA: SV301 CM200 VideoCam repair-Easy for N-Scale!
Vadim - 10.06.13 19:04
===========EN and DE languages=================
===================EN========================
SV301 CM200 VideoCamera repair Easy for N-Scale!
Or: Everyone can easy install video into it's own locomotive now!
Hello.
Continuing attracting people into engineering field of making jazzy usefull and developing things , let us speak about N-Scale Locomotive VideoCams. We live at 2013 Year now! There are lot of Chinese cameras everywhere! Among them there is a very small SV301 CM200 Wireless Camera. It have 8 video channels at 2.5GGz frequency region, color and sound! It has 8 mm width and height! It can be easily inserted into variety kinds of N-Scale locomotives! This Camera costs as little as 25 dollars! It's extremely cheap!
BUT!
This camera works short period of time, and not so dependable. Damage occurs when supply voltage is non-constant, and have short absence periods. This may happen at any N-Scale locomotive at railroad modelling layout! After detailed inspection i understood, that Chinese people havent enough knowledge in Electronic Engineering! Namely: Digital CCD sensor is connected to universal VMicro chip. This chip requires connection of Read Only Memory (ROM). This ROM chip stores CCD setup data. VMicro read it during startup. Chinese people substitute Read Only Memory onto Electrically Erased Programmable Read Only Memory (EEPROM) (first error), and forget to solder write protect pin to +U. Therefore any unstability in power supply can lead to unrecoverable damage of functionality!
HOW TO TREAT CM200 from Chinese-ability:
In aim to repair CM200 Video Camera
do the following before usage:
For NEW CAMERAS:
1) Disconnect pin7 of EPROM from GND and connect it to pin 8 (+U)
Now Your cameras will work and work even at extremly unstable electrical pickup which exists at N-Scale locos.
For DAMAGED CAMERAS:
1) Take good camera.
2) de-solder EEPROM.
3) Download all data into IBM-PC-AT use PonyProg and very simply COM-port programmer:
(http://www.lancos.com/prog.html ). )
4) Take EEPROMs from damaged cameras and program it with good data.
5) Solder it back
6) All cameras must continue work!
As a result: We have not so Chinese cameras now at 25 dollars!
It's work well now !
HOW TO GET IT:
This Cameras easily can be riched at variety internet stores:
For head CM200:
http://www.bevrc.com/bev50mw-24g-wireless-mini-cam_p217.html
For Full pack CV301 with receiver :
http://fpvhobby.com, http://rf-links.com
See CV301 Manual:
http://www.foxoffer.com/24g-mini-coms-wireless-...14.html#.UbYL_9jppkQ
PHOTOS:
CM200:
http://img-fotki.yandex.ru/get/6715/5475818.10/0_8c0bb_28f132ed_L.jpg
CM200 opened:
http://img-fotki.yandex.ru/get/9165/5475818.10/0_8c0c3_11aa11aa_L.jpg
CM200 unfolded (For V200, V120 locos )
http://img-fotki.yandex.ru/get/9220/5475818.10/0_8c0be_59793e97_L.jpg
How to TREAT it: (making write protection)
http://img-fotki.yandex.ru/get/9217/5475818.10/0_8c0bc_3d520ed2_L.jpg
V200 equipped with this camera inside view:
http://s3.uploads.ru/t/W9PNQ.jpg
Impulsive power supply view:
http://img-fotki.yandex.ru/get/9115/5475818.10/0_8c0c1_7297701b_L.jpg
Schematic of connection into LocoDecoder:
http://img-fotki.yandex.ru/get/9225/5475818.10/0_8c0ba_a5c9b119_orig
Schematic of Dead Space Removing device :
http://img-fotki.yandex.ru/get/9152/5475818.10/0_8c0b9_1d373b49_orig
Dead Space Removing device View:
http://img-fotki.yandex.ru/get/9219/5475818.10/0_8c0c0_a478aefc_L.jpg
VideoClip of Working Locomotive with VideoCameras:
http://www.youtube.com/watch?v=cD-7cixKD80
Vadim
===================DE========================
SV301 CM200 VideoCamera Reparatur Einfach für Spur N!
Oder: Jeder kann einfach installiert Videos in seine eigene Lok jetzt!
Weiterbildung zieht Menschen in Engineering-Bereich der Herstellung und Entwicklung von jazzy nützliche Dinge, lassen Sie uns über N-Maßstab Locomotive Videokameras sprechen. Wir leben in 2013 Jahr jetzt! Es gibt viele chinesische überall Kameras! Unter ihnen gibt es eine sehr kleine SV301 CM200 Wireless Camera. Es haben 8 Videokanäle bei 2.5GGz Frequenzbereich, Farbe und Klang! Es verfügt über 8 mm Breite und Höhe! Es kann leicht in verschiedene Arten von Spur N Lokomotiven eingesetzt werden! Diese Kamera kostet so wenig wie 25 Dollar! Es ist extrem billig!
ABER!
Diese Kamera arbeitet kurze Zeit, und nicht so zuverlässig. Schaden auftritt, wenn die Versorgungsspannung nicht konstant ist, und haben kurze Fehlzeiten. Dies kann zu jeder Spur N Lok Eisenbahn Modellierung Layout passieren! Nach eingehender Prüfung habe ich verstanden, dass die Chinesen genug Wissen havent in Electronic Engineering! Nämlich: Digitale CCD-Sensor ist universell VMicro Chip verbunden. Dieser Chip erfordert eine Verbindung von Read Only Memory (ROM). Das ROM-Chip speichert CCD-Setup-Daten. VMicro las es während des Startvorgangs. Chinesen ersetzen Read Only Memory auf elektrisch gelöscht Programmable Read Only Memory (EEPROM) (erster Fehler), und vergessen zu löten Schreibschutz Stift + U. Daher ist jede Instabilität in der Stromversorgung nicht behebbare Schäden von Funktionalität führen!
HOW TO CM200 von Chinesisch-Fähigkeit BEHANDLUNG:
In Ziel zu reparieren CM200 Videokamera
Gehen Sie wie folgt vor Nutzung:
Für neue Kameras:
1) Trennen Pin7 von EPROM von GND und an Pin 8 (+ U)
Jetzt Ihre Kameras arbeiten und arbeiten auch bei extrem instabilen elektrischen Aufnehmer, der an Spur N Loks existiert.
Für beschädigte KAMERAS:
1) Nehmen Sie eine gute Kamera.
2) de-Lot EEPROM.
3) Laden Sie alle Daten in IBM-PC-AT Verwendung PonyProg und sehr einfach COM-Port-Programmierer:
(Http://www.lancos.com/prog.html). )
4) Nehmen EEPROMs von beschädigten Kameras und programmieren sie mit guten Daten.
5) Solder es zurück
6) Alle Kameras muss weiterhin Arbeit!
Als ein Ergebnis: Wir haben nicht so Chinese Kameras jetzt bei 25 Dollar!
Es ist jetzt gut funktioniert!
Wie man es:
Diese Kameras können leicht in verschiedene Internet-Shops angereichert werden:
Für Kopf CM200:
Für Full Pack CV301 mit Empfänger:
Siehe CV301 Handbuch:
FOTOS:
CM200:
CM200 geöffnet:
CM200 entfaltet (Für V200, V120 Loks)
Wie sie zu behandeln: (was Schreibschutz)
V200 mit dieser Kamera Innenansicht ausgestattet:
Impulsive Stromversorgung Blick:
Schematische Darstellung der Verbindung in LocoDecoder:
Schematische Darstellung der Dead Space Entfernen Gerät:
Dead Space Entfernen Gerät anzeigen:
VideoClip der Arbeitsgruppe Locomotive mit Videokameras:
Vadim
Hello.
BUT!
For NEW CAMERAS:
5) Solder it back
HOW TO GET IT:
For head CM200:
See CV301 Manual:
PHOTOS:
CM200:
CM200 opened:
Vadim
ABER!
Für neue Kameras:
2) de-Lot EEPROM.
5) Solder es zurück
Wie man es:
Für Kopf CM200:
FOTOS:
CM200:
CM200 geöffnet:
Vadim
Beitrag editiert am 11. 06. 2013 10:41.
Hello again!
Are there anybody who prefere to play as real train driver watching tracks and signals from cab videocameras of model locomotive?
Are there anybody who already have locomotive model with VideoCameras?
Vadim
Vadim
Hi Vadim,
impressive what you are able to stuff into such a tiny loco :) Keep it up!
Carsten von 1001-digital
Thanks, Viele !
I think, that technical progress starts now to allow inserting technical vision systems in N-Scale models of locomotives.
Vadim
Vadim
