THEMA: digitalumbau steuerwagen
lok albahn - 07.08.13 19:53
Hallo, bitte hör auf in LokPilot esu pilot zu digitalisieren einem Steuerwagen? Ich möchte auch auf Digitalsound BR 218 Fleischmann setzen: Welche Decoder empfehlen Sie Dank? Vincenzo
ADMIN: Missglückte Umfrage gelöscht - cancelled erratical survey - erronea sondaggio cancellato
Michael Peters - 07.08.13 20:24
Dear Vincenzo,
I think it would be better, if you describe your problem without using a google translation. Please write in English or Italian. It would be easier to understand.
Bye.
Felix B.
PS: Es scheint mir, als müssten einige vor lauter lange Weile immer Ihre Meinung sagen, auch wenn Sie unmöglich verstanden haben können, worum es eigentlich gehen soll. Wie kommen sonst die 3 Stimmen zusammen?
Bye.
Felix B.
Beitrag editiert am 07. 08. 2013 20:53.
lok albahn - 07.08.13 20:55
Ok e grazie per il tuo interessamento felix.Io voglio digitalizzare una carrozza pilota della fleischmann con un lokpilot ESU e non so come fare.Puoi aiutarmi?
inoltre voglio digitalizzare col sonoro una BR 218 fleischmann. ,quale decoder della ditta D&H devo utilizzare?
Grazie a tutti per il vostro aiuto!
Vincenzo
Vincenzo
I would use a DH05C for the 218 and an FH05 for the "carrozza pilota". You can configure both to the same address, then you can use the front and back light in either direction.
Best regards,
Thomas.
Best regards,
Thomas.
Hi Vincenzo,
For the "Steuerwagen", you can have a look at my conversion here in English:
http://www.digitrainworld.com/2013/02/fleischma...th-decoder-lighting/
or in French if it's easier for you:
http://fr.digitrainworld.com/2013/02/wagon-fleischmann-n-avec-decodeur-eclaira/
I used a cheap "FD-R Basic" from Tams Elektronik (2 functions out, about 11€).
As suggested above by Thomas, you could use an FH05 from Doehler und Haass (about 18€). This decoder is a bit better: it has 4 outputs. If you install interior lighting, with a FH05 you could control it separately.
As for the locomotive with sound, I personally prefer ESU Loksound Micro v4.0 products.
If it's too big, maybe you could look at the "SL76" from Ct-Elektronik (Tran.at).
Best,
Pierre
lok albahn - 07.08.13 21:44
Ciao e grazie
ma il sonoro dove lo posso alloggiare nella locomotiva? Grazie
vincenzo
vincenzo
lok albahn - 08.08.13 00:10
Hallo pierre,
but dcc SL 76 reproduces The sound of locomotive BR 218? THANK YOU
vincenzo
vincenzo
Not exactly. The "SL76/DI" is a generic diesel sound:
http://www.tran.at/Produkte/SL76.shtml (use Google Translate)
For the BR218, there is the ESU Loksound Micro ref. 54833:
http://www.esu.eu/en/products/loksound/available-sounds/
Hi Pierre
There are a lot of sounds available for the SL76, I think I may have one for the BR218.
Carsten von 1001-digital
lok albahn - 08.08.13 11:25
Hallo carsten,
can you have any decodersound for my BR 218 original?
can you help me?
best vincenzo
can you help me?
best vincenzo
Hi Vincenzo,
I'll be back from my holidays at the weekend. I can look into my list then.
Hi Vincenzo,
In http://sounds.huebsch.at/ ci sono suoni per il DB218 di Carsten anhören.Diese sono disponibili per il gioco anche.
gruß Werner
Google- Übersetzer
gruß Werner
Google- Übersetzer
lok albahn - 08.08.13 16:47
danke catsten und vielen dank an sie zu werner!
Vincenzo
Vincenzo
lok albahn - 08.08.13 17:48
Hallo where is can it install to speaker in locomotive br 218?
bedt
vincenzo
bedt
vincenzo
