THEMA: Auhagen 14472 - Lights in Rooms
Vadim - 06.10.13 17:49
Hello.
I made blinking lights in MultiFlat buildings.
The solution is quite simply, without any processors and programming:
See Clip: http://www.youtube.com/watch?v=KpoyKalDCts
How it's made: (PhotoGallery and Schematic):
http://fotki.yandex.ru/users/vadimav/album/174093/
Vadim
Vadim
Gibt es jemand, der blinkende Lichter in Gebäuden?
Are there anybody, who made blinking lights in buildings?
Nice work, thaks for your post.
In a way your solution is simple, but in another way not, cause it needs a lot of work.
Blinking lights: I did with a ready to use module.
Some time ago someone presented a solution based on DCC here in the forum. If I want to equip more houses, this will be my choice.
Hello Vadim,
if you use a Arduino-Board you can do it very flexible.
Its very easy to use!
Look at my homepage
http://www.herberts-n-projekt.de/basteleien-1/belebtes-haus/
Best regards
Herbert
Look at my homepage
Best regards
Herbert
->Blinking lights: I did with a ready to use module.
QUESTION: Please tell me name and catalogue number
-> if you use a Arduino-Board ...
QUESTION:
You unsolder the Microprocessor from pre-programmed Arduino board, and solder it to LEDs?
(quite unclear how to do it)
QUESTION:
Hello Vadim,
you find more information on Arduino Homepage and in the forum many very interesting projects.
http://www.arduino.cc/
http://forum.arduino.cc/
regards
Herbert
regards
Herbert
->you find more information on Arduino
Yes. I already visited it. But i dont understand how to choose chips, write code, program external chips and make it with LEDs.
I think that You buy Arduino, program it via USB, and, then, unsolder chip from Arduino MotherBoard, and then, solder it to LEDs. Right?
As we can see and estimate, it's a quite big and separate thing!
If You know it - It's quite good! You can use it in RailRoad modelling simply and fastly!
Sorry, but I dont know it at all. To learn it - will l require a lot of time to learn data, processor language,...etc.
With the other hand: Making of layout - very big task itself! There is no extra free-time!
Therefore I prefere to buy ready to use modules, or use quite simply solutions at not so critical things as lights in buildings.
@4
It is named KORRPUS and includes pieces to seperate the lights within the building.
http://www.modellbahnservice-dr.de/Zubehor/Hausbeleuchtung/hausbeleuchtung.html
1) I cannot open instruction or PDF using this link for "Korpus". There is even no any image of device.
2)As to Arduino: I must buy these boards, and learn programming language. May be, soldering LEDs to processor would be a bit simpler, but i must spend a lot of time, learning processor architecture and system of it's commands, then, i must write my own code, debig it.... etc...
Korrpus - a link with Pictures:
http://www.modellbahnhof-geringswalde.de/shop/k002u001s001.htm
The product is maybe at it's end of lifecycle
Uwe Spengler - 08.10.13 09:50
Privét Vadim,
there is also the light computer LC-11 ( http://www.conrad.com/ce/en/product/217346/ ) from TAMS ( http://www.tams-online.de/htmls/produkte/lc/produkte_lc.html ).
I use it in two detached houses, and it looks very good there.
Regards,
Regards,
Thanks to all for Your respond!
Hello Uwe! I read about Tams! I would need 12 per one my Auhagen building = 120 Euros
But they are sufficiently big in size to place it inside buildings.
As to Korrpus:
I need to read PDF on electronic board and watch pictures of corrpus electronic board to estimate sizes.
Vadim
As to Korrpus:
Vadim
