THEMA: Need wiring diagramm for EcosLink 50305 cable
Vadim - 11.06.14 17:14
Hello. I need wiring diagramm  for EcosLink 50305 6 to 7 pin  mini-din cable.
There is no railroad modelling stores there.
Please give me wiring diagramm.
My Aim - Connect ECoS IR Navigator to ECos-2 via ECoS link.
Thanks,
Vadim
Hi Vadim, unless you live in North Korea or on top of a mountain with only donkeys delivering the mail, there are surely many train stores than can only deliver to your place
Here is an example, they might be able to deliver to your country:
http://www.modellbahnshop-lippe.com/produkt/ESU...-gb-h-0/produkt.html
If you want to build the cable yourself, then I am afraid I cannot really help you. Google "mini din 7" and "mini din 6" (separately), then look at the images with the numbers of the pins. Assuming the last pin of the 7 plug is not paired towards the din 6, then maybe you can just ignore it. Be careful, this is at your own risk.
Why not go to esu.eu and post on their forum? They have an English speaking one.
Pierre
Thanks, Pierre. Esu forum is still silent about it.
If You have such cable, can You check wiring connection by tester and type this results?
Thanks,
Vadim.
Hi Vadim,
have you tried to write an eMail to ESU? This should be the most reliable source of information about this...
Carsten von 1001-digital
ESU support and forum still silent. If anyone have EcossLink, can You test connection between 6 and 7 pin mini din  jacks by tester and publish results here?
